Author Topic: My new layout design.  (Read 266294 times)
« Reply #1530 on: December 21, 2022, 07:23:34 AM »
Very, Very Cool....... Looking great Jörg  :thumb:
« Reply #1531 on: December 23, 2022, 12:01:29 PM »
so I've spent some time on my layout again.
Planning and doing.
I need a station building, which I want to be similar to the old Faller kit B 99 Station Lindental.
So I've started to build a mock up from cardboard.
The original is a bit to small, so I'm changing a few dimensions and also the design a bit.
Yesterday afternoon during load shedding i took everything outside and worked on the garden bench.
First few pieces cut.
Then carefully started assembly and later in the evening I placed it on the layout.
« Reply #1532 on: December 23, 2022, 12:03:59 PM »
That's not all I've been busy with.
The back section I have been placing and gluing my mountain scene.
Not all section will be secured though as for access I will need to have a few removable sections.
« Reply #1533 on: December 24, 2022, 11:23:40 AM »
Beautiful Jörg.  :thumb:
« Reply #1534 on: December 25, 2022, 11:43:49 AM »
so my cardboard station is taking shape.
Otherwise I'm just enjoying running a few trains.
« Reply #1535 on: December 25, 2022, 11:27:39 PM »
Good evening all,
the cardboard mock up of the station is taking shape.
The restaurant is wider now and slightly longer. Biggest change is that
I have the restaurant on both sides of the building now.
See photo.
The outer big wall clock will be set back a bit.
This is the first time that I'm doing something like this with cardboard.
I must say that I prefer styrene.
When I build the actual station it will be in styrene.
I have also made this building slightly higher, but a bit narrower.
« Reply #1536 on: December 27, 2022, 10:59:04 PM »
That is going to look awesome Jörg.
Really GREAT work so far.
« Reply #1537 on: December 28, 2022, 09:17:58 AM »
I agree, this will look amazing.  :innocent: :biggrin:
« Reply #1538 on: December 30, 2022, 09:05:17 AM »
Love it!  :thumb:
« Reply #1539 on: January 08, 2023, 09:41:59 PM »
Good evening all,
small update.
Been fiddling around with some lights.
I am trying to have an illuminated control panel in my signal tower.  :eek:  :eek2:
Optic fiber and Led's.
This is a first attempt.
« Reply #1540 on: January 09, 2023, 09:16:17 AM »
Seems to be working ok... :innocent:
« Reply #1541 on: January 17, 2023, 05:46:29 PM »
Good day all,
after a few hours gluing fiber optics to Led's and then trying to get everything into that small
space its been quite a disappointment.
So back to the drawing board.
« Reply #1542 on: January 22, 2023, 08:05:22 AM »
Good morning all,
I've done quite some work on the signal tower.
I have fitted secondary walls to the inside, to make them smooth as this model
does not have straight internal walls.
See pics one and two.
Then I also made real wooden walk boards outside, I didn't like the cast on plastic
ones.
Pic three.
« Reply #1543 on: January 22, 2023, 02:09:50 PM »
Nice Jörg, much better  :biggrin:
I used cardboard to build the internal walls of my HO Station.
Works well and it is easy to shape and paint and hide all the window stuff you glue from the inside.
Real wood for the walkways is brilliant, did not think to do that  :eek:
« Reply #1544 on: January 24, 2023, 08:57:25 AM »
Good morning on this rainy day, perfect model train weather.  :)
The control panel in the signal tower is taking shape.
Looks much better in real life.
But it still needs a few tweaks.
