Author Topic: My new layout design.  (Read 265866 times)
« Reply #1500 on: November 06, 2022, 09:41:01 PM »
Good evening all,
I've done a bit of work during the week on the wall and tunnel portal.
The tunnel tube and portal are now glued in place.
The lower extension to the wall as well.
Later once the track has been ballasted, the overhead masts fitted then I will
camouflage the gaps a bit.
« Reply #1501 on: November 08, 2022, 08:46:21 AM »
« Reply #1502 on: November 08, 2022, 05:14:07 PM »
Looks good!  :thumb:
« Reply #1503 on: November 08, 2022, 10:33:53 PM »
Thanks for the thumbs up
Tells me that I'm on the right path.
Small change, I have stepped the top wall extension and glued it down.
Busy with a secondary retaining wall in front now.
« Reply #1504 on: November 10, 2022, 07:32:47 AM »
Good morning all,
small update. I have widened the track board coming out of the tunnel.
Second photo shows the extra retaining wall.
« Reply #1505 on: November 10, 2022, 06:29:12 PM »
some time ago I had started with the rock section between the walls.
Only as a styrofoam block, but I now cast a few rocks to try and complete this.
First place a few castings in place to get a feel for it.
Pic one.
Then today on the garden bench I fitted these castings with plaster of paris.
Pic two.
Last two pics of the rock formation in place to check for fit.
Still needs some work.
« Reply #1506 on: November 10, 2022, 06:30:50 PM »
Sorry I had to split the post as the four pics together exceeded the max.  :)
« Reply #1507 on: November 11, 2022, 07:41:27 AM »
Awesome job Jörg,
That is looking GREAT  :thumb:
« Reply #1508 on: November 12, 2022, 11:06:52 AM »
Thanks Evert.
So I have now also fitted rock castings to the other section.
« Reply #1509 on: November 13, 2022, 09:15:11 AM »
Good morning,
yesterday I still glued in this rock formation.
Last night I then filled in the gabs.
The cling wrap is there to keep the walls clean and to also allow me
to remove the walls again.
« Reply #1510 on: November 13, 2022, 06:11:30 PM »
Schön, immer weiter. :thumb:
« Reply #1511 on: November 17, 2022, 10:59:42 PM »
Good evening all,
the plaster has set and I've had some fun with color.
« Reply #1512 on: November 17, 2022, 11:02:49 PM »
I've also spent some time on my freight shed.
Cast in the tracks and a base.
Not really dry yet so have to wait a bit longer.
« Reply #1513 on: November 20, 2022, 03:51:10 PM »
busy with the corner rock section that needs to stay removable.
Been building up the corners and sanding to fit.
« Reply #1514 on: November 21, 2022, 07:59:22 AM »
Good morning,
so last night I placed all the parts together to have a look what
it will look like.
Even if I say it myself, but I'm quite happy how this is turning out.  :thumb:
