Author Topic: LooVille Extention to a L shape....  (Read 71595 times)
Re: LooVille Extention to a L shape....
« Reply #210 on: August 24, 2017, 05:02:47 PM »
Nice Evert!  :thumb: :thumb: :thumb:
« Reply #211 on: August 28, 2017, 07:51:55 AM »
Good Morning All  :biggrin:
I had some nice time this weekend and got lots done.
I soldered and fitted the lights into the factory and I also fitted the factory to the layout.
Decided to siff some sand to get it really fine and used that for walkways and roads. Lots still to do, but next I have to get the point motors to work nicely.
Here is some pictures  :thumb:
1st is while I'm busy doing the grass and finishes.
2nd - 4th is just nice.....
5th is with the lights on. I think it looks quite good, I like it.....
Enjoy.
Hope you all have a great week.
« Reply #212 on: August 28, 2017, 08:20:26 AM »
Awesome.  :thumb:
Are you still going to have some outside lamps?
« Reply #213 on: August 28, 2017, 10:32:45 AM »
Awesome.  :thumb:
Yes definitely  :thumb:
I'm going to fit these ones from WoodlandScenics, but I still have to buy them.
https://woodlandscenics.woodlandscenics.com/show/Item/JP5638/page/1
« Reply #214 on: August 28, 2017, 11:18:27 AM »
Those look fantastic, can't wait to see a night time shot of the layout.
« Reply #215 on: August 29, 2017, 01:57:27 PM »
Mpf... I sit here with a open mouth!
« Last Edit: August 31, 2017, 04:03:41 AM by trainmaster »
Offline Georgecape
  • Jr. Member
« Reply #216 on: August 30, 2017, 06:36:17 PM »
+1 (meaning +1000)
« Reply #217 on: August 31, 2017, 08:26:04 AM »
« Reply #218 on: September 11, 2017, 07:48:41 AM »
So I finally took the trestle bridge out that I built.
Ai, I should have taken it out while the cretestone was still soft and not 1 year later  ??? But, what is done is done....
So I manage to get it out  :thumb: I then painted everything and did all the base work. Painting and grass.
Picture 1 is where the bridge is fitted back.
Then I also started with the track. I wanted to move all the sleepers together, saw this on quite a few pictures, so I thought it is a bit more prototypical.
I started to cut away all the plastic bits in between the sleepers.
Picture 2 and 3 - top and bottom.
Took quite a while doing this, but I think it look quite nice.
Then I cut the track to length and fitted and soldered the points in.
I still have to finish the track off, 2 sections to fit still, then I'll connect it to the existing piece that come out of the tunnel.
Then I can start to work on the Sawmill again  :biggrin:
Cheers, speak again and enjoy the pictures.
« Reply #219 on: September 11, 2017, 08:33:21 AM »
I like the detail of the sleepers being closer together on the bridge, are you going to install
guard rails as well?
« Reply #220 on: September 11, 2017, 08:50:14 AM »
Jip, I'll do the guard rails before I fit the track to the layout. I fitted guard rails to the bridges on the section I take to shows also, but did not do the close sleepers. I might just lift the rails to change that.....  :innocent:
« Reply #221 on: September 11, 2017, 12:22:32 PM »
Nice detail! :thumb:
« Reply #222 on: September 11, 2017, 06:54:59 PM »
Nice evert!  :thumb:
« Reply #223 on: September 12, 2017, 08:15:48 AM »
Good morning All,
Small update.
Last night I finished the track and I installed the Rail Guards  :biggrin:
Next I have to make boxes for the fitment of the point motors. Then once that is installed I can permanently fit the track.
« Reply #224 on: September 12, 2017, 08:26:51 AM »
