Author Topic: LooVille Extention to a L shape....  (Read 71158 times)
Re: LooVille Extention to a L shape....
« Reply #15 on: January 16, 2015, 03:08:40 PM »
You'll need to switch to N scale first.  :thumb:
The other alternative is to have a layout room that is almost twice the size.  ;)
« Reply #16 on: January 16, 2015, 06:35:18 PM »
[/quote]
Niel,
This is where (HO)rribly oversized ferroequinologists get the benefits on (N)ormal wrong; it equates to FOUR times the footprint, not merely double !
Steve ;D
« Reply #17 on: January 16, 2015, 07:18:53 PM »
[/quote]
I stand corrected
« Reply #18 on: January 19, 2015, 07:38:15 AM »
As promised, I did some work over the past week and weekend and I think I have a yard with all the steam equipment that can work and that I'm happy with.
The grid is 100mm
The green section is my current layout. I will keep it as a module that I can take to the shows. There will be a few changes I have to make, but it is just on the 3 lines in front of the station.
Then the 2 red rectangles is the new layout.
Top left will be hills with a Castle.
Top right will be mountain (RoundHouse will be up against the slopes of the mountain) all the way to the left connecting with the hills.
Right edge will have a bridge and middle back just before the point will be a wooden trestle bridge.
The two grey sections of track will go to a second layout below. This will be just to store 3 or 4 built up trains.
Please give me your input and comments.
Lots of work and time is going to go into this layout, so I want it to work well.
Thank you and speak again.
« Reply #19 on: January 19, 2015, 08:00:38 AM »
looks great, just have one question, is there a reason that the section of track in the red circle is so curved?
Regards Jörg.
« Reply #20 on: January 19, 2015, 08:20:56 AM »
Yea, I'm not to sure about that bit hey. I could not make it work as a curve and still have it bigger than 300mm.
I think I will sort that part out when I actually build it. Will have to see...
« Reply #21 on: January 19, 2015, 08:31:57 AM »
Okay, when you build try and do that section with flextrack.
You should then be able to get a nice smooth line with an easy radius.
Cheers Jörg.
« Reply #22 on: January 19, 2015, 08:58:15 AM »
Jip,
I build with Peco Flex Code 80. I have about 100m 4x boxes of it at home already and I have about 20 left and 20 right Electrofrog points.
So I think I can get a far way.
I just need to buy all the wood for the bench work still. Then everything can start.  :thumb:
« Reply #23 on: January 19, 2015, 09:04:04 AM »
100 meters of N scale flextrack, wow how far do you want to extend your layout?  :thumb:
« Reply #24 on: January 19, 2015, 12:21:45 PM »
To the street it seems  :biggrin:
« Reply #25 on: January 19, 2015, 01:23:03 PM »
Evert, I think this will give you a lot of fun. You might have to make a tweak or two when you build it, but it looks stunning so far.
« Reply #26 on: January 20, 2015, 09:41:43 PM »
That can work.
As Jörg pointed out the S-bend that he circled is a concern but you've already addressed that.
Otherwise it looks good to me.
« Reply #27 on: January 21, 2015, 07:06:49 AM »
Thank you very much for all the comments.
Thank you Niel for responding. And yes, as Ed also said, I'll have to tweak one or two things as I build.
Nothing is cast in stone.
Once all the bench work is done and the buildings footprints is made I will pack the track out and then we see again.
But I'll keep everything and averybody up to date with the progress. I'll be doing a full build pictorial again  :thumb:
Can't wait to start.
« Reply #28 on: January 21, 2015, 06:44:41 PM »
No worries.  Keep us posted
« Reply #29 on: January 21, 2015, 08:15:09 PM »
Hi Evert
This looks to be a seriously interesting topic to follow. Having never built a layout ill be sure too learn a trick or 2.
