Author Topic: Märklin BR 05 with ESU Loksound  (Read 5168 times)
« on: August 09, 2018, 05:16:24 PM »
another conversion is completed.
This loco came from Märklin with a decoder and sound module.
The steam whistle sounded ridiculous in my opinion so it just had to go.
At the same time I also fitted warm white Led's.
First photo Loco opened and checking how much space there is.
Second photo no matter how the speaker will not really fit in the smoke box.
Re: Märklin BR 05 with ESU Loksound
« Reply #1 on: August 09, 2018, 05:17:21 PM »
The offending decoder and sound module.
« Reply #2 on: August 09, 2018, 05:18:07 PM »
Sound module unplugged from decoder.
« Reply #3 on: August 09, 2018, 05:22:08 PM »
Seeing that I want to use a ESU 21 MTC adapter board to mount the decoder I need a
base to mount this on. Made one from vero board and stuck the adapter board on with
two sided tape.
Yes it had to be mounted at a slight angle.
« Reply #4 on: August 09, 2018, 05:25:02 PM »
Seeing that the Led's for the rear lights are mounted underneath the original decoder I had to
do the same here.
Glued the Led's on standing up and then the next day with a little bit bigger solder blob connected
them to the board.
Working.  :thumb:
« Reply #5 on: August 09, 2018, 05:35:41 PM »
Then I started testing and setting all the CV's.
Had a problem in that the smoke unit stayed on permanently. ???
I checked and rechecked my work, a few times using my multimeter and check
all connections for shorts to any others and everything showed up perfect.
So I studied the ESU decoder instructions a bit more, there are so many CV's to adjust
and set up its scary.
This morning I found my ESU decoder tester and immediately connected that up and plugged
in the decoder.
Well here it worked correctly and I could switch F 1 on and off as I pleased.
So the problem had to be in the loco.
Dismantled it again and rechecked every connection and solder joint with a magnifying glass.
Ah, I found a tiny solder blob between two solder pads.  :-[
Removed that and everything is perfect.  :thumb: :thumb: :thumb: :thumb:
Fitted a 2200µf cap and but everything back together.
Stay tuned for the next project.  :)
« Reply #6 on: August 10, 2018, 01:39:49 PM »
Well, I am speechless.  :thumb: :thumb: :thumb:
« Reply #7 on: August 13, 2018, 07:13:54 AM »
AWESOME  :thumb:
Would love to see that one go  :biggrin:
« Reply #8 on: August 23, 2018, 08:54:58 PM »
A echte kunstenaar!
« Reply #9 on: August 27, 2018, 03:37:50 PM »
My favourite German loco!  :thumb:
