Author Topic: BR 03 154  (Read 16536 times)
Re: BR 03 154
« Reply #45 on: August 01, 2026, 04:17:29 PM »
little by little this project is progressing.
I've started to think about holding the body of both loco and tender for the final spray painting and have come up with
a plan.
Cut some wood, got some M 5 threaded rod and nuts and put my plan into action.
Result,  :thumb:
Note the use of wing nuts for easy adjust ability.
I've made a second one for the tender as well.
Re: BR 03 154
« Reply #46 on: August 02, 2026, 01:02:00 PM »
Here's how the tender body is held.
Wing nut from the inside as this clamp works the other way. It spreads to hold the body.
Re: BR 03 154
« Reply #47 on: August 02, 2026, 01:05:49 PM »
Then I discovered that I can use a vice to hold my project to work on it.  :thumb:
I've also got the air pipe for my new air brush sorted and did a few practice sprays on some paper
this morning to get to know my double action internal mix air brush.
I had up to now only had experience with a external mix single action air brush.
Re: BR 03 154
« Reply #48 on: August 09, 2026, 10:06:43 PM »
well I have finally fitted all the parts.  :thumb:
Now I need to clean everything, fine grit blasting.
Basically sand blasting, but using fine aluminium oxide powder.
Then primer.
Then paint.
Re: BR 03 154
« Reply #49 on: August 10, 2026, 04:33:21 PM »
a semi successful day.
While grit blasting the loco body I unfortunately damaged the one smoke deflector.  :rant: :lamer: :-\ ??? ::) :eek2:
Will have to repair this now.
Anyway I did blast the other parts as well.
Re: BR 03 154
« Reply #50 on: August 10, 2026, 09:55:33 PM »
Tender body and chassis primed.
Re: BR 03 154
« Reply #51 on: August 11, 2026, 04:17:55 PM »
today I managed to prime the loco body.
 ;D
Re: BR 03 154
« Reply #52 on: August 19, 2026, 09:24:07 AM »
It's coming together very nicely! Well done so far.
I might have missed it somewhere but I saw no centre pickup on the loco, or will that go to the tender?
Re: BR 03 154
« Reply #53 on: August 20, 2026, 09:14:04 AM »
Thanks Ed,
it's a Fleischmann loco for the Märklin system.
Pick up shoes is under the loco chassis from the factory.
Re: BR 03 154
« Reply #54 on: August 20, 2026, 09:17:42 AM »
unfortunately I have had to strip the tender body again as I've had a mishap
with the painting process.  :(
But I've now painted the loco body and cab.
Next step is to get the Led's into the lamps in front and the cab.
« Last Edit: August 21, 2026, 09:09:00 AM by capeklr »
Re: BR 03 154
« Reply #55 on: August 20, 2026, 09:19:45 AM »
I will have to try and take some better photos.
Re: BR 03 154
« Reply #56 on: August 21, 2026, 09:07:14 AM »
last night I started with the wood paneling in the cab.
Also a nice way to hide the wires for the cab light.
I also cleaned and painted the headlight reflectors white.
Now to carefully glue the tiny Led's into the headlights.
Re: BR 03 154
« Reply #57 on: August 22, 2026, 09:14:06 AM »
first Led is in the headlight.
Has to be positioned carefully and secured with clear coat. This allows me time to get it positioned nicely.
Re: BR 03 154
« Reply #58 on: August 24, 2026, 12:51:47 PM »
well this morning I fitted the circuit boards for the lights inside the loco.
Temporary connected to my power supply to test.
Decoder will go in later.
Re: BR 03 154
« Reply #59 on: August 31, 2026, 09:25:33 AM »
a bit more progress on this project.
Tender has been resprayed, I didn't quite get a clean line between the red of the buffer
beam to the black of the rest of the tender body. I guess that i'll have to help a bit with a small brush.
