Author Topic: My new layout design.  (Read 266276 times)
« Reply #945 on: October 29, 2018, 12:50:02 AM »
Good job Joerg! :thumb: :thumb:
« Reply #946 on: October 29, 2018, 07:08:07 AM »
small update and a accident. Must be the heat, to much gin and tonic.  >:D
Fitted some more locos with magnets for the signalling and then.
See for yourself.
Oh Nooooooo  :o
« Reply #947 on: October 29, 2018, 07:15:39 AM »
Then I have been busy with my Led room lighting.
I have finally bought all the Led strips that I need as well as the pipe
to use.
Cut the pipe to length and then into five more or less equal strips.
Reflective tape inside and then a double row of Led's.
First one up, three more to go.
Working through a dimmer on 12V so that I can later incorporate this in my control panel.
Nice, I like the LED's, but is the lighting OK? I found that LED's does not give the same visibility as normal lights.
« Reply #948 on: October 29, 2018, 08:09:18 AM »
 :thumb: :thumb:
Switch to brandy and coke.... much nicer accidents!  >:D
« Reply #949 on: October 29, 2018, 08:32:47 AM »
Yes the light is quite different, these are cool white while the down lighters, also Led's are warm white.
I am sure that once I have all four strips up the light will be strong enough.
Time will tell.
« Reply #950 on: November 03, 2018, 08:36:24 PM »
Saturday update time.
Empty staging yard?
What am I up to now?
« Reply #951 on: November 03, 2018, 08:37:53 PM »
Lights, what else. :)
This is with all other light off.
« Reply #952 on: November 03, 2018, 08:40:11 PM »
Both staging yards illuminated as well as the
Led strips on the ceiling.
These are dimmed down in the photo.
« Reply #953 on: November 03, 2018, 08:45:03 PM »
I have this week also completed all four Led ceiling light and mounted them.
On full power its a lot of light and then as these are dimmable I can set the lights
very soft.
« Reply #954 on: November 04, 2018, 04:44:55 PM »
Very nice Jörg.  :thumb: :thumb:
« Reply #955 on: November 04, 2018, 07:46:44 PM »
Joerg, that's perfect! You planned well. ;)
« Reply #956 on: November 05, 2018, 07:07:25 AM »
Very nice, must say the LEDS give a nice effect too your trainroom.
Hope you have a good day.
« Reply #957 on: December 19, 2018, 09:06:22 PM »
no update.  :-[
Just some photos.
King Ludwig is on his travels again and passing through my layout.  :thumb:
« Reply #958 on: December 23, 2018, 08:41:10 AM »
Very nice, but- I'm missing the driver and the stoker on the loco... :peep:
tarinmaster
« Reply #959 on: January 09, 2019, 10:17:05 AM »
small update. :)
I needed a fence, so I built a jig to drill and cut some tooth picks.
Black arrows point to the two holes to be drilled with a 0.5mm drill bit through the tooth pick.
The red arrow is the cut off line.
