Author Topic: My new layout design.  (Read 266272 times)
« Reply #480 on: July 28, 2017, 11:51:36 AM »
I have deleted all my photo's with photobucket and have now joined postimage and have hopefully fixed all the poto's so far for this thread on the first 4 pages.
I some members could check for me if the photo's are displaying correctly please let me know.
Thank you.
« Reply #481 on: July 28, 2017, 01:49:30 PM »
Hi Jörg,
Jip, page 1 to 4 looks fine. 5 onward you obviously are still busy with  :thumb:
« Reply #482 on: July 28, 2017, 02:16:44 PM »
Thanks for the feedback.
Offline Georgecape
  • Jr. Member
« Reply #483 on: July 30, 2017, 05:59:52 PM »
Hi Wesley,
these I bought from Eco Led a few years ago.
Still have a few off cuts let so used one here.
Warm white with silicon sealed water proof strip.
These strips come in 5 meters and can be bought just about anywhere nowadays.
Saw this on Bid or buy in Cape Town:
500mm Long Led Strip Aluminium 5630 White: **IN STOCK**R20.00
Specifications:
Input Voltage: 12V-12.7V DC (Connect direct to 12V Power Supply or 12V Battery)
Current Usage: 480mA
Led Chip Size: 5630
Led Count:  36 Leds
Wattage: 5.5 Watts
Colour: White
Strip Size: 500mm Long x 12mm x 1.2mm Aluminium Circuit Board
* You are able to cut this strip at any length at 41mm intervals and wires can easily be soldered onto + and - pads. This strip comes with 10cm Wire on already.
« Reply #484 on: July 31, 2017, 11:30:25 PM »
So I had some time the last few days to fit all the backdrops.
Those big sections from Faller are not easy to work with and unfortunately
it didn't always go that smoothly.
Starting to go up.
« Reply #485 on: July 31, 2017, 11:33:20 PM »
Long section done, now to consider where to cut this one and at what
height to fix it.
Prestix to the rescue, up, down left and right and then I got my idea.
« Reply #486 on: July 31, 2017, 11:34:57 PM »
« Reply #487 on: August 01, 2017, 07:05:47 AM »
Awesome, looks great  :thumb:
I can imagine that it would have been quite a challenge.
Well done  :biggrin:
« Reply #488 on: August 01, 2017, 07:39:00 PM »
Nicely done Jörg. Sehr schön!  :thumb: :thumb: :thumb:
« Reply #489 on: August 01, 2017, 08:46:38 PM »
Hi Joerg!
With all your circumstances you told me, the result is avesome.
treainmaster
« Reply #490 on: August 10, 2017, 04:18:20 PM »
Small update.
Did a bit of woodwork and metal work.
A few holes in the wall and another layer is coming up.
Need to go and buy some wood now.
Corner done.
« Reply #491 on: August 10, 2017, 05:01:33 PM »
Nice!  :thumb: :thumb: :thumb:
« Reply #492 on: August 10, 2017, 05:48:13 PM »
Awesome.... now more track  :thumb: and some more trains can run..... nice one Yörg.
« Reply #493 on: August 29, 2017, 09:45:54 PM »
been quiet here on my thread, but tonight I have a small update.
I've done some metal work, wood work, glued down some cork roadbed and laid a few pieces of track.
Only 19 pieces of flex track and a few pieces of sectional track.  >:D
I have also had the first section of baseboard for the main station in the room to check for fit.
Basically the rear long straight section, which is also the highest part of the layout is now done.
« Reply #494 on: August 29, 2017, 09:47:25 PM »
Station baseboard to check for fit.
