Author Topic: My new layout design.  (Read 266297 times)
« Reply #1050 on: September 11, 2019, 09:57:56 PM »
added another piece of cardboard to my station entrance for some more planning.
Unfortunately I will have to reduce the width of the station a bit as the space
to walk through is just to narrow.
Some re planning coming up.
« Reply #1051 on: September 12, 2019, 06:51:29 AM »
Nice..... Ai, yea we have to sacrifice a bit at the end, but it will look good.
I assume it is going to sit on that level correct? Very nice.
« Reply #1052 on: September 21, 2019, 09:57:45 PM »
 :lamer:
Was running a few trains a short while ago and set a wrong signal.  :rant:
Had to untangle three trains from each other.  ::)
All sorted and no damage.  8)
« Reply #1053 on: September 22, 2019, 11:58:52 AM »
 :thumb: It will happen. ;)
« Reply #1054 on: September 25, 2019, 07:40:45 AM »
Oh No  :eek:
Jip, it happens to the best of us.
As long as there is no damage, it is all good.
« Reply #1055 on: October 06, 2019, 07:44:01 PM »
small update, did a bit of electrical work on the one staging yard this weekend.
No pictures of that, its only wires. ;)
In between fixing the memory I was also busy with a few good coaches.
I have 3 pairs of these two axle log loaders that are always coupled in pairs.
The one set had is coupling rod missing so I made my own some time back.
In the end I preferred the self made coupling so I ended up doing the same for the others.
1st photo.
Then I applied a bit of rust and some other weathering and finally sprayed them with a fine layer
of matt clear coat.
Some nice logs to finish it of.
« Reply #1056 on: October 07, 2019, 07:05:37 AM »
Nice, very cool wagons....  :thumb:
« Reply #1057 on: October 07, 2019, 05:47:05 PM »
We like it Jörg, Very nice.  :thumb: :thumb:
« Reply #1058 on: October 08, 2019, 08:16:08 AM »
Very nice!
« Reply #1059 on: December 27, 2019, 01:12:31 PM »
last post early October, that's not good, but sometimes can't be helped.
Small update.
I decided to buy some layering glue for applying static grass as whenever I had
tried to had another color or layer to existing grass I discovered it always ended up the the lower
level getting all stuck together.
So I surfed you tube to get some tips on using this product and then tried it for myself.
« Reply #1060 on: December 27, 2019, 01:17:24 PM »
One of the spots which I did not like as I had tried to do some layering here
in the past.
Without removing anything I just sprayed on the layering glue and applied a few different
colors of grass.
The good thing is it does not just stick everything together in a big clump.  :thumb:
Before and after photos.
« Reply #1061 on: December 28, 2019, 12:19:22 PM »
 :thumb: :thumb:
« Reply #1062 on: January 01, 2020, 04:54:47 PM »
Happy 2020 everybody.
To ring out the old year I let a few trains run and for a while
I had four trains running simultaneously.  :thumb:
Got quite busy for a while.
« Reply #1063 on: January 03, 2020, 07:42:37 AM »
That’ll keep you busy oraait. :biggrin:
« Reply #1064 on: January 03, 2020, 12:23:21 PM »
 :biggrin: :biggrin:
