Author Topic: FS: Electrical items - track voltage tester and CDU  (Read 1400 times)
« on: April 19, 2016, 12:11:18 PM »
Hi all
I made contact with Colin at EMRIG and now have some items up for sale here in Cape Town. If you want anything else / more, I am sure Colin can / will help.
Prices differ due to postage cost.
I have 3 x CTT01 @ R35 and 1 x CTT02 at R95 left.
See link for more info. I can add these items are beautifully made (don't look home made at all, rather professionally made).
http://emrig.co.za/?page_id=1537
Re: FS: Electrical items - track voltage tester and CDU
« Reply #1 on: April 19, 2016, 03:01:15 PM »
More info from link
Quote
Electronic Gadgets from Colin Tanner-Tremaine
Track Voltage Detector ref CTT01.
A simple hand held device that will quickly indicate if there is voltage on the track. Designed to work with DCC but will also indicate the presence of Volts on analogue DC circuits if the voltage is turned up.
PRICE R25.00 each, postage/delivery extra.
See attached pamphlet for more details. Track Voltage Detector,
Capacitor Discharge Unit ref CTT02
A compact device that will operate standard solenoid operated point motors. Requires a 15/18 volts AC supply and will energise 2-3 point motors. With extra capacitor will operate up to 5 solenoids providing wiring between CDU and point motor is suitable.
Price R 75.00 each, postage/delivery extra.
See attached leaflet for more information. CAPACITOR DISCHARGE UNIT
DCC Current Sensing Unit ref CTT04c
This unit is capable of monitoring the flow of current drawn from the DCC supply by a locomotive or any wagon that pulls current from the track. If this current exceeds approx. 5 mA it operates a 2 pole change over relay whose contacts can then be used to control signals, lights, sounds and indicate to a computer or automation system in which section the train is currently located.
Price R125.00 each postage and delivery extra.
See attached leaflet for more information.DCC Current Sensing Unit rev b2
Control Relay Unit Ref CTT05a
This is a Printed Circuit mounted 2 pole change over relay with decent terminals for making off small wire connections. Ideal for use on model railways for extra controls for instance increasing circuit connection off point motor switches, frog switching, and simple interlocking applications.
Price R35.00 each, postage and delivery extra.
See attached leaflet for further details.Control Relay Unit
