Author Topic: Digitrax Zephyr Xtra  (Read 3112 times)
Offline rickbotha
  • Let there be steam!
    • TrainTry
« on: October 21, 2015, 06:43:06 AM »
Hi Guys,
I've been doing quite a bit of research with regards to DCC, and my heart seems set on the Digitrax Zephyr Xtra due to its expandability, the fact that it has a physical cab, etc. I have looked the the z21, and the Z21, but they fall way outside of my budget at this stage, and I would want a physical cab like a MultiMaus along with the z21 as a touch screen doesn't feel as if it will be as much fun as the hands-on experience.
I'm not in the market for anything yet, will probably only be able to buy something next year, but who are the most reasonable suppliers to get it from locally, or is it cheaper to import? Is there possibly anyone selling one 2nd hand?
Thanks for the info  ;D
Rick
Re: Digitrax Zephyr Xtra
« Reply #1 on: October 21, 2015, 10:20:21 AM »
Rick, my layout will be operated by a Z21 system this weekend. I personally use a Digitrax Zephyr, but then I will not be operating my own layout this weekend :biggrin:
Check it out with Juan...
Offline rickbotha
    • TrainTry
« Reply #2 on: October 21, 2015, 06:56:54 PM »
Thanks BigEd,
I hope I can make it, we'll see :)
« Reply #3 on: October 21, 2015, 08:48:39 PM »
Rick,
The most important thing about selecting a DCC system is to select one that you understand.
The Digitrax systems aren't bad.  The Zephyr Extra (DCS51) is a good choice as it has the capabilities to run small to medium layouts, read and write programming features and is expandable through Loconet to easily allow for extra throttles, boosters or other peripherals.  One thing to be aware of.  If you get a Zephyr Extra make sure it is supplied with the South African power supply.  There is something with the US type power supplies that doesn't play well with our local electricity supply.  Due to this it may be wise to look at one of the local dealers.
Another system that isn't half bad is the ESU Navigator.  It comes with a hand held control that communicates via infra-red.  Additional cabs and IR receivers can be added to the system.  It's pretty easy to switch between different locos on the fly.  The system also has read and write capabilities.
I have no experience with the z21 systems (in either flavor) so I can't comment to much.  Sure it runs from smart devices, but I could do that with my Digitrax equipment a long time ago already.  That said people who aren't so technically advanced seem to like them and think they are capable and easier to use than Digitrax systems.
My layout currently uses two Digitrax Zephyrs (the older DCS50 model) as well as some UT4's a Dt400 and even some old UT1's.
If you have specific questions about the different models then feel free to ask.
HTH,
« Reply #4 on: October 26, 2015, 08:15:39 AM »
Hi Rick,
I also use Digitrax.
I have the following....
-Digitrax Zephyr DCS 51
-UT4 Throttle
-UR90 Infrared Receiver Front Panel
The system works well and is easy to operate and expand.
I also have Digitrax DCC chips in my Loco's (you don't have to) and it really works well.
Enjoy all the research.
Evert Loo
