Author Topic: LooVille Marklin mini-club Double track Layout  (Read 15061 times)
Re: LooVille Marklin mini-club Double track Layout
« Reply #45 on: December 21, 2022, 04:01:30 PM »
........ Step 2 .........
I do not have the plans, so I traced the shaped onto news paper, cut it out and redraw on the the Plexiglass.
Then I used my Dremel to cut it, works extremely well.
This is going to look awesome  :thumb:
« Last Edit: December 21, 2022, 04:03:28 PM by LooVille »
« Reply #46 on: December 21, 2022, 09:58:46 PM »
........ Step 3 .........
All the blue pieces was cut.
Now for the white one.
Need the track to make sure everything lines up where it is supposed to....
« Reply #47 on: December 21, 2022, 10:30:47 PM »
I stripped everything off the original board.
Cleaned all the track and transferred it over to the new layout.
Then I tried to fit the turntable so it make sense and so that it will work.
Making sure I can park a loco and also have enough space to run it off through the turntable onto a siding and back onto the layout.
Think this will work well.......
I used Lego to pack as the turntable need 40mm clearance  :biggrin:
« Reply #48 on: December 21, 2022, 10:32:50 PM »
........ Step 4 .........
Last few cuts for the main layout.
Final test fit before I start to glue the layers together......
« Reply #49 on: December 22, 2022, 07:11:26 AM »
I can see the kids running to mommy, dad is stealing our Lego.  ;D
« Reply #50 on: December 22, 2022, 03:35:55 PM »
I still like the original more??? Maybe I'll reserve final judgement till I see it in real life... :innocent:
« Reply #51 on: December 23, 2022, 08:25:42 AM »
Wow, this really stunning. Very Nice.  :thumb:
« Reply #52 on: December 27, 2022, 11:05:57 PM »
Good Evening All.
OK, some more work was done, facia fitted  :biggrin:
« Reply #53 on: December 27, 2022, 11:09:35 PM »
Then just to make my life a bit more difficult I decided to make the bridge from clear Plexiglass  :eek:
I also bought a 8mm clear rod. This I cut 6mm and 3mm pieces for the supports.
« Reply #54 on: December 27, 2022, 11:13:36 PM »
No I can put the track back.
Everything is back on and spaced and taped.
Next is to drill the holes for the wires.
Then I can fit the catenary base plates again and then permanently fit the track.
« Reply #55 on: December 28, 2022, 09:16:59 AM »
Just amazing.  :thumb: :biggrin:
« Reply #56 on: January 19, 2023, 07:50:11 PM »
Right, last small stretch for the layout.......  :biggrin:
Catenary is back in place.
I also marked and drilled the holes for the wiring from the points and the track power.
Then the big task to do all the wiring. Wow  :eek: took 3 days to complete, but I'm happy.
Everything is tested and is working like it should.
« Reply #57 on: January 19, 2023, 07:55:19 PM »
I also added some feet to the layout again. 100mm x 40mm 3mm Plexiglass block with a rubber bottom.
Just round it off nicely.
I have also cut in some handles on the fascia and glues in some wooden blocks on the back. It is quite surprising on how heavy this layout have become.
« Reply #58 on: January 20, 2023, 08:14:26 AM »
