Author Topic: Faller B-148 coaling station, my attempt to build a working model.  (Read 19220 times)
Re: Faller B-148 coaling station, my attempt to build a working model.
« Reply #45 on: August 25, 2020, 08:57:33 PM »
small bit of progress.
I modified the second servo tonight and connected it to the power supply.
Fitted the gear and viola the cab can turn.
For now just loosely holding it in my hand, but my idea works. :thumb: :thumb:
Now to properly mount this servo with some space left for electronics.
Stay tuned.
« Last Edit: August 30, 2020, 06:43:56 PM by capeklr »
« Reply #46 on: August 27, 2020, 09:53:01 PM »
okay I mounted the servo last night with some contact glue just to hold it in position.
It works. :thumb:
The system still needs a bit of fine tuning and I need to reposition the winch servo by 1 mm to the side.
Then I need to figure out the electrics.
« Reply #47 on: August 30, 2020, 06:46:34 PM »
Oops.
I wanted to paint the frame of the crane, due to the cold weather I carefully warm it up a
bit with a heat gun.
To much. ::)
Fortunately only the one ladder sustained damage.
« Reply #48 on: August 30, 2020, 06:50:39 PM »
Then I finally found the base for this project which I built a few years ago.
Note the slot in the plywood, a small rod will pro dude through this slot and move the crane from side to side.
Some N scale track which will be cut in half  so that I have one on each side for the crane to roll on.
« Reply #49 on: August 30, 2020, 06:52:45 PM »
Off course for the crane to work there has to be a drive system.
Old printer motor with a toothed belt much like a cars cam belt.
Some electronics with limit switches. :thumb:
« Reply #50 on: August 30, 2020, 07:30:55 PM »
Just awesome Jörg.  :thumb: :thumb: :biggrin: :biggrin:
« Reply #51 on: September 01, 2020, 07:31:59 AM »
Very, Very Nice Jörg.....
Starting to come together now.....
« Reply #52 on: September 06, 2020, 05:44:37 PM »
this drive system was direct and the only way for me to control the speed was to reduce voltage.
Problem then is that the motor looses a lot of power.
I have been thinking about a geared speed reduction.
Today I made up a bracket to hold the gear and toothed belt sprocket, this will be pulled off the motor,
the motor will then get a 16 tooth gear to mesh with the 60 tooth gear on the shaft.
That will give me a 3,75 : 1 gear ratio allowing the motor to turn faster while reducing the speed of the crane.
Need to get a 3 mm reamer this week so that I can enlarge he holes in my two gears to fit the sprocket and shaft of the motor.
Here is a photo of the new set up, parts are just placed loosely so not straight.
« Reply #53 on: September 06, 2020, 09:12:50 PM »
Coming on nicely.  :thumb:
« Reply #54 on: September 08, 2020, 08:12:50 AM »
Nice..... This is really going to look awesome when it is operational.....
« Reply #55 on: September 08, 2020, 03:45:58 PM »
so today I had a few minutes and quickly turned the spacer needed for the gear.
All assembled.
« Reply #56 on: September 08, 2020, 03:48:34 PM »
To much Gin and Tonic.  :biggrin: O:-) :lamer: :loco:
I start to assemble everything and then.  ::) ::)
Those two gears are supposed to mesh.  :eek2: :eek2:
Back to the drawing board.
« Reply #57 on: September 08, 2020, 07:39:07 PM »
I'ts close!  :D
« Reply #58 on: September 08, 2020, 07:45:14 PM »
That's better.  :)
Now it works.  :thumb:
« Reply #59 on: September 12, 2020, 06:37:52 PM »
no real work done, but I did find the two coal bunkers and can now place everything
together to check for fit and how it will look together.
I did glue down a sheet of cork which will now be the foundation for all the other things on this.
Just a few photos of what this looks like now.
Will play around with this for a few days and think it through.
