Author Topic: My new layout design.  (Read 266300 times)
« Reply #180 on: May 29, 2016, 11:20:05 PM »
Well done Joerg! I wait for the first (official) running train...
« Reply #181 on: May 30, 2016, 07:52:42 AM »
Awesome progress Jörg  ;D
Looking awesome.... As for the castle, I would do a small tunnel. I like that on the scenery and it breaks the flow a bit also.
To me it makes a layout interesting.
« Reply #182 on: May 31, 2016, 09:44:05 PM »
Small update tonight.
Continued with the up ramp to the first bridge.
Must still get a few supports, but the basics are there.
« Last Edit: August 24, 2017, 07:57:58 PM by capeklr »
« Reply #183 on: May 31, 2016, 09:46:47 PM »
Then came a big moment when I hung in the first bridge.  :biggrin:
It fits.
My plan is coming together.
« Last Edit: August 24, 2017, 07:59:35 PM by capeklr »
« Reply #184 on: May 31, 2016, 09:51:07 PM »
As you will have noticed I like to use threaded rod building my layout.
On the hidden sections I just let the rod and nut sit on top, but on the visible sections I don't want that.
So I made a few fittings which are basically a piece of flat plate with a nut welded to it that can be fitted to the
bottom of the board with 2 small wood screws.
So with one threaded rod I can support 2 layers. Most probably even more.
« Last Edit: August 24, 2017, 08:00:47 PM by capeklr »
« Reply #185 on: May 31, 2016, 09:54:23 PM »
The more I think about this the greater the possibility that I will try it.
Let see what it looks like when I get to that level.
« Reply #186 on: June 01, 2016, 07:32:36 AM »
Awesome progress..... and well done on the first bridge  :biggrin: always a good feeling.
The layout is really starting to take shape nicely now, love it.
« Reply #187 on: June 01, 2016, 10:30:25 AM »
I want to have the castle as the highest point on the layout.
Can't make up my mind if I must have a short tunnel under the castle or if I must bring that large curve a bit more forward
to have the trains visible all the way around.
[/quote]
Hi Jorg,
At the risk of being labelled a nitpicker, rivetcounter or whatever, I would think it highly unlikely that a tunnel would run directly under a castle.   The foundations would be immense and the vibration from the rail traffic would likely unsettle the structure.
Steve (heading for cover) :happydays:
« Reply #188 on: June 01, 2016, 01:15:49 PM »
Hi Steve, no need to run for cover.  ;D
That is the beauty of a forum like this, you can discuss ideas and also get different opinions.
You are quite right, I doubt that a tunnel would be built under a castle.
There is a railway line very close to the original castle in Austria that this model is based on.
Your thought also gives me another idea, if I do run a tunnel under the castle I could always model some dungeons with skeletons for the trains to run through which can then seen by the camera car.  >:D
« Reply #189 on: June 01, 2016, 07:05:19 PM »
Very nice Jörg.  :thumb:
« Reply #190 on: June 03, 2016, 09:19:03 PM »
Hi everyone,
small update from me.
Checking that there is enough clearance for my biggest unit to get over the bridge, I would have preferred a short straight section before the bridge, but the available space dictated that was not to be.
No problems.  :thumb:
« Last Edit: August 24, 2017, 08:02:50 PM by capeklr »
« Reply #191 on: June 03, 2016, 09:21:47 PM »
Last night I build a frame for the upper section.
Coming together.
Completed and mounted.  :thumb:
« Last Edit: August 24, 2017, 08:04:21 PM by capeklr »
« Reply #192 on: June 03, 2016, 09:26:17 PM »
Here's a photo with the 180° corner.
Tonight I temporally mounted my controls, this will most likely stay here till I build and complete my main control panel.
I have also already connected the first booster as that will be needed once I start wiring the upper staging yard.
Enjoy.  :thumb:
« Last Edit: August 24, 2017, 08:05:32 PM by capeklr »
« Reply #193 on: June 03, 2016, 11:20:06 PM »
Nice one Jörg......
That is some serious progess......
Awesome to follow the progress...
Enjoy and I'm following closely  :thumb:
« Reply #194 on: June 04, 2016, 01:07:28 PM »
Hi Joerg!
Avesome ... but when you like to sleep? :peep:
 ;D ;D
