Author Topic: My new layout design.  (Read 266292 times)
« Reply #1110 on: December 21, 2020, 11:11:52 PM »
Good evening everybody,
all four through tracks on my station are completed.  :thumb: :thumb:
« Reply #1111 on: December 21, 2020, 11:16:42 PM »
So the only station track that still needs to be done is the dead end
track for the push/pull commuter train.
Still not quite sure how long to make this.
Will think it over before I lay any track.
« Reply #1112 on: December 22, 2020, 02:06:07 PM »
Awesome...... Looking Good......
« Reply #1113 on: December 22, 2020, 05:03:01 PM »
Sehr schön Jörg!  :thumb:
« Reply #1114 on: January 03, 2021, 07:14:31 PM »
I trust that we all made it into the new year okay.
I spent the evening alone running trains from 2020 till well into 2021 with a bottle
of bubbly.  ;D
The bottle must have had a hole in it, as it emptied in one evening.  >:D
Anyway in the meantime I have fitted the uncoupler tracks that I had forgotten.
I also fitted the servos and decoders for these on the one side and connected them up and programmed them.
Unfortunately one of the decoders is dead.  :rant:
So that will have to wait till the next order from Germany.
I have now also found the signal tower that I want to use on this layout.
I have the kits for years in my cupboard and it took me a while to find these.
Two of the same kits as I want to build one out of the two making it a bit longer to span more tracks.
That is why I have the two upper bases lying on the tracks where I want to fit this.
« Reply #1115 on: January 03, 2021, 07:16:57 PM »
Found another kit as well, goods shed.
Will see if this works here or not.
May get a bit cramped.
« Reply #1116 on: January 04, 2021, 02:45:55 PM »
Nice kits...
« Reply #1117 on: January 05, 2021, 09:27:40 PM »
so this evening I took a big step and removed something.
Even some tracks. >:D
Don't worry, its only the temporary loop that been there so long it was in danger of staying there.
Gone it is. :thumb:
« Reply #1118 on: January 05, 2021, 09:31:29 PM »
Naturally I did not stop there and have started to get all my gradients lined up.
Red arrow on second photo shows where the gradient down starts on the rear line.
Hopefully I will have the trains doing a full loop in a few days.  :thumb:
Lower staging yard that has been dormant for a few years has been cleaned and the trains are
running there as well.  :thumb:
« Reply #1119 on: January 06, 2021, 08:38:36 AM »
Awesome Jörg, nicely done. !  :biggrin: :thumb:
« Reply #1120 on: January 06, 2021, 10:57:23 PM »
Good evening,
a bit more was done today.
Had to re drill a few holes in the wall as the brackets where to high.
Starting to get the gradient right.
Also joint the two plywood track boards, one coming from the top and the other one from the station.
Then I layed the outer track loosely, this is the fixed track 902 mm radius.
It lines up pretty well.  :thumb: :thumb:
Then I glued down the inner cork roadbed.
« Reply #1121 on: January 06, 2021, 11:03:55 PM »
Just for fun, I was standing on a small wine barrel and turned around to this view.
Had to press the shutter again.
I'll have to tidy up a bit.
« Reply #1122 on: January 07, 2021, 12:38:00 PM »
Awesome Jörg!  :thumb:
Only a light dusting required.  ;)
« Reply #1123 on: January 07, 2021, 04:45:54 PM »
Agreed....awesome  :thumb:
« Reply #1124 on: January 07, 2021, 10:21:01 PM »
All is well and we are safely back from holiday also  :thumb:
Great work Jörg......
I like that Signal tower, going to be awesome if you can extent it over all those track...... Nice.
I have to start building on my HO as well, but to many other things at the moment, but we will get there.
Anycase, speak again.
