Author Topic: Hi I'am George from Kenridge  (Read 10761 times)
Re: Hi I'am George from Kenridge
« Reply #15 on: May 19, 2017, 01:07:24 PM »
Are you going standard gauge or narrow gauge?
Offline Georgecape
  • Jr. Member
« Reply #16 on: May 19, 2017, 02:35:20 PM »
Wow, what does that mean?
My mind is living in the world of model trains and the track width is about 32mm - real trains don't exist for me ;D
Offline Georgecape
  • Jr. Member
« Reply #17 on: May 19, 2017, 02:42:53 PM »
Photo of the LED dimmer with remote and 2 9V batteries (nearer 16V) working well.
The loco is too light so I added a 5lb sinker and now there's no wheel spin. No idea how long they will last. Grandson was dancing around with joy (I think he was born with a remote in the hand).
But my fingers are in the way all the time ;D
« Last Edit: June 02, 2017, 10:26:43 AM by BigEd »
Offline Georgecape
  • Jr. Member
« Reply #18 on: June 01, 2017, 06:16:20 PM »
Can anybody pse tell me where I can find gears for a Lima O scale train as per photo. The worn gears (I have 2 units) are on the main rotor shaft axle.
« Last Edit: June 02, 2017, 10:27:20 AM by BigEd »
Offline Georgecape
  • Jr. Member
« Reply #19 on: June 01, 2017, 08:01:22 PM »
Sorry about the photos I'll work on getting it right ;D
« Reply #20 on: June 01, 2017, 09:17:16 PM »
Hi George,
reduce the size of the photo first in a program like Windows Paint.
Have you got a photo of the gears?
Diameter inside and outside as well as number of teeth?
« Reply #21 on: June 02, 2017, 10:27:46 AM »
Fixed!  :thumb:
Offline Georgecape
  • Jr. Member
« Reply #22 on: June 02, 2017, 03:55:44 PM »
Fixed!  :thumb:
Yes. Teeth = 12 and shaft dia = 2.5 and gear dia = 8mm
I am wondering if I shouldn't replace the motor wit a new type brushless. With the Dremel I can cut away the housing and make a new housing from wood and position a new motor.
The restrictions are height 35mm and width 35mm max.
Any advice appreciated :)
Offline Georgecape
  • Jr. Member
« Reply #23 on: June 02, 2017, 04:10:11 PM »
Correction: gear dia 7mm
« Reply #24 on: June 02, 2017, 04:45:52 PM »
Ouch that looks bad.
I suspect that gear is part of the shaft.
If not would be tricky to pull off and press a new one on if you can get.
If you can go the new motor route that might be a good option to explore.
I do have pullers and a press.
Offline Georgecape
  • Jr. Member
« Reply #25 on: June 02, 2017, 06:37:25 PM »
Thks. I got some advice from a local model car shop and he advises me to slip in a cpte new brushed motor into the existing housing (after removing the magnetic stator) that can accept a new gear which he has. It's 11 teeth and dia 6.5 and shaft dia 2mm - not quite the same but I'll give it a try?
