Author Topic: Track advise Please  (Read 10414 times)
Re: Track advise Please
« Reply #15 on: September 30, 2016, 03:21:18 PM »
What ?   So you can see how much crap I store on my layout ?? :loco:
I have you beaten... :innocent:
« Reply #16 on: September 30, 2016, 04:18:41 PM »
Dream on knucklehead.
Just to prove Ed wrong, photos of how I trim cork before ballasting.   And please note how clean the background is.
Offline gazza23
« Reply #17 on: October 01, 2016, 10:33:48 AM »
Thanks Steve,
I have noticed that the cork wasn't cut in line with the end of the tracks, I've also seen that some people cut the edge of the cork at an angle, what's the difference between the two.
Thanks Gary
« Reply #18 on: October 01, 2016, 10:47:42 AM »
Hi Gary,
To achieve a 45' angled cut, the cork need to be cut before laying or you risk trimming the edges of the ties.   By using a wider cork cut, and trimming after the track is laid, allows for track alignment/realignment to best fit when putting track down.
The standard off the shelf cork roadbed with cut edges gives a very wide swathe of ballast that looks nothing like the prototype.
« Reply #19 on: December 13, 2016, 10:57:09 AM »
muche has been answered but I will add my 2c
NEVER EVER USE CHIPBOARD OR MDF!!!!  en of story. PLywood, 9mm MINIMUM, 12mm is better.   if your layout will be stationary, you can use sheets of plywood. if you might need to move it, build a 'box frame' with braces, and only place plywood where your tracks will be. the rest is vovered with polystyrene sheets. this allows for a lightweight yet strong structure.
as for track...
you get thin double sided tape. looks like cellotape. you will find it in craft stores - look in the paper craft/scrapbooking section. horribly expensive...    use normal wood glue to lay your cork.  1 lesson, split the cork in 2 narrow strips (for n scale about 7mm wide and HO about 10mm wide).   draw the centre line of your track. now glue the strips of cork on either side of the centre line, and use normal sewing pins or thumb tacks to keep the cork down.   the reason for splitting the cork is to keep it flat when doing curves.  the wider the cork is, the more it will buckle when doing a curve, up to a point, and then it will break, or cause crappy track work.   in yards and under points, use larger pieces of cork than the track, glue down a sheet in the yard.
also as said, cut the edge of the cork BEFORE glueing down, I use a steel ruler and a stanley carpet knife at an angle.
« Reply #20 on: December 13, 2016, 11:09:35 AM »
Good advise from the renegade.
Just wanted to add - I use contact glue to lay my cork strips. Yes, the 2 parts with the centre line works like a dream!
The last thing to remember - ALWAYS SAND YOUR CORK BEFORE LAYING TRACKS!!! It makes a big difference in the leveling of the track.
